schiker
OK, I got mixed up with my math (as usual long plug and chug I end up making an error). At 3400 rpm you would get 2x the amount of fuel per minute since 2x the rpm of 1700. But same per revolution Duh. However, the rate of camring/plunger lobe pump action is 2x as fast so I still believe the peak line pressure is at least 2x as much at 3400 rpm than at 1700 rpm. I bet timing of the solenoid closure would affect the internal IP pressure too
I think the issue is not whether the motor can take the extra fuel and timing issues (surely it can since propane doesn't kill engines). I think its if the IP drivetrain doesn't shear off the drive pin ????? When max fuel rates are delivered at high rpm depending on injector orifice timing and setup etc. What else might affect it?
I have a DS4 IP in pieces and measure approximately (calipers) the plunger at 0.375" dia. The cam ring diameters are 1.956" big to 1.906" small.
If I am understanding this right....
There are 4 plungers and 8 lobes. One pump high to low cam position would be .375" diam x .1" long (diameterically opposed plunger 2x radial stroke). It will do this 4 times per rev of the IP rotor.
So lets try and calculate what it could theoretically pump through IF all the fuel could be injected.
I think the IP turns at 1/2 crank speed right ?
92mm^3 per 1000 strokes is what per each cam lobe stroke (4 per IP rotor rev) or per rev of the IP rotor???
