scottm
I think some block cracks and crank failures may be due to excessive injection advance. Do electronic 6.5's adjust injection timing based on engine sensor readings, ie, do they sense knock or should I say excessive knock? It seems like a fine line between normal detonation and damaging detonation, which you might not be able to tell apart from the sound.
