DS4 IP experts
If you do decide to go the OBD2 path, don't spend time or money by playing with resistors. Just put in the correct OE value resistor and let the computer do the work. Incorrect resistors just fools the computer and makes it think it is doing one thing, when in reality the IP is doing something different. Put another way, with a non-OE value resistor, the only time the mixture is correct is at idle. Once asking for power, the system is out of balance and usually on the rich side. The better way to get different fuel levels is via the power tables in the software. But last I checked, the only way to get different fuel levels is just to change the desired power for a given throttle value.
I was never sold that OBD1 was really any different than OBD2 when it came to the resistors and fueling.
This IP was on a motor that failed, the owner says he thinks it was working when it was removed.
The prom I'm using is a prom quadstar sent me to use for this testing on my stand. I do have the owners prom I'll swap and try to see if that makes a difference.
I could swap a db2 in to prove the motor, but that is a lot of work and doesn't show the owner the motor is right with his IP, so I'll keep working to see if I can get this figured out. I'm sure it's not the PCM as the motor I ran a month ago was perfect with a new IP so it's something with this pump I think... I'll wait till the owner gets back in town to see what he wants to do..
It’s the IP
It’s the IP
I have a spare that I can send to @Twisted Steel Performance
Try it out and see if it runs with that.
It is the pump that was on my engine when I bought the truck.
It was throwing an advance code. Replaced the advance stepper motor and have not tried it since.
The original stepper motor was froze solid. New one could ratchet in and out with the actuator plunnger.
The optical sensor has nothing to do with it. I once had similar symptoms: erratic operation, black exhaust. If I disconnected the optical sensor, it ran smoothly but had a high idle. I fixed this by slightly tightening the solenoid by about 30°. This reduced the gap between the solenoid plunger and the metering needle. The engine now ran smoothly and quietly.
The malfunction may reoccur. The problem is that the PCM commands fuel injection through the FSD, but the valve closes inconsistently—sometimes it closes, sometimes it doesn't close, sometimes it's tight, sometimes it's loose. Because of this, the actual injection is inconsistent and unpredictable. The PCM attempts to adjust the injection timing and duration, which causes the engine to jerk.
This is either wear of the needle and seat, or dirt, or chips, or an increased gap between the solenoid pusher and the metering needle.
Something I did not see in your timing sequence, did to have ECT above 170F commanded TDCO will not occur on a cold engine, it has been a moment since I worked an OBD-I, but for sure OBD-II requires that. The way I set for -1.94 TDCO is to set base time in time set to-3.8/-4. vs. factory -3.5, let engine warm up about 175F ECT, shut off engine then with APP to floor then CYCLE KO/KO for a minute and restart, where it will stumble/learn new TDCO, if not where you want it bump a little more to driver side -4.2/4.6 in time set for an little more TDCO if 1-.5 or better I leave it there as not much difference -1.5 vs. -1.94 on my trucks. Now if you have a T2 or similar tool that negates having to do KO/KO with APP to floor, but I think temps above 170F are required for TDCO learn to be active even with Tech 1 or 2 tool.
Yup.
From Quadstar Tuning I got the temperature fooler.
Engine has to be warm enough that GP cycle is not needed but engine does not have to be as warm as required by the ECM to shove it into timing learn mode.
