North Maine
Merchant Mariner
like iamdave's question, this isnt a "6.5" thing, more of a 6.5 body style thing... by interior drivers door handle just failed, all of the sudden. How hard is this to repair?
I have replaced a few myself....I could have sworn that they are held in with rivets from the factory that had to be drilled out...its been a few years since I've done it though....
wing style on mine were riveted in, replaced drivers side last year, LMC truck is where I got the new one, self tapping screw/bolt on the replacement
Yup, same here. Drilled rivet out and replaced with a screw.
IMPORTANT: Make sure after you replace your handle, you bend your rod so you need very little pull on the new handle to open the door.
Thanks for the tip because my driver door handle is broke also!
"The Old arm out the window to open the door trick!"
Been there many times.....major PIA.
Louis
my problem is the linkages, the handle is fine, its just it wont do anything now
