dbrannon79
I'm getting there!
On my 93 I have been letting my youngest son drive it around to get some practice on larger vehicles.   one thing he said was how much stiffer the throttle pedal is compared to all the other vehicles we have including my 95 truck.   when I first got it on the road I too noticed right away how stiff the pedal was but just dealt with it.
I am curious hearing from others who have driven both trucks with DB2's and DS4's along with other cable driven vehicles to see if it's just me or there is something I need to tend to on this rig.
I did attempt to pull the cruise cable off along with removing the double spring from the IP just to see if that made any difference. the cruise cable didn't seem to change anything but by unclipping the double spring on the IP the pedal was much easier to press but did not return, (that was a given as it needs a spring)
looking at the angle of how the throttle cable goes through the bracket and pulls on the lever on the IP it's at what I call a steep angle meaning that where it's pulling from it looks to me that it would take more force than if it were at a different angle pulling.
I also know that the throttle shaft that is on this DB2 is one for a hummer not for a truck as it has the provisions for the two wire TPS for military applications. not sure if that makes a difference. I do have a throttle shaft made for the truck version of this IP and the side where the cables attach are different. I have never gotten myself enough courage to attempt swapping them out. Afraid I would get stuck with an IP I couldn't get back together LOL.
If I were able to swap out the throttle shaft, I could eliminate the cable driven TPS and use the three wire GM one for the trans controller too.
I know @Will L. has experience with the military versions of the DB2's. this one even had the 24v shutoff solenoid until I swapped the top cover out.
Whats everyone's experience with how much resistance or how hard the throttle pedal should feel on these trucks? for my 17 year old driving it, he tells me he feels like he's flooring it compared to others, he cant use his toes to press the pedal and needs to almost full foot it like the brake pedal. I will admit that it will tire my foot out driving long distances without the cruise control! Thank goodness that does work LOL.
