randomid25
Rattle-Trap Cap'n
I'm trying to research the db2's and to learn more about them. My pump is maxed out and i still have yet to see more than around 700 degrees egt in 4th gear with the tc locked up accelerating up a hill. That is with my turbomaster set at 8psi peak boost.
I know that the first numbers of the pump
DB = pump model
2 = number of plungers
8 = 8 cylinders
29 = .29 inch plunger diameter
and i also understand that the 6.5 has db2831 pumps which ammount to larger plungers but I am trying to understand the difference between the different models of 2829 and 2831 pumps. There has to be variances in these or else they would all have the same numbers after the first 4 (ex. they would all be db2829-4268 or whatever).
Someone please school me on the differences. I may be looking to go to a bigger IP soon because i feel like i have some more hp to be had from my setup.
DB = pump model
8 = 8 cylinders
