john65td
Addicted to boost
Got some questions bout my ipc when i put my blinker on my voltage gauge jumps from 14 volts where it normals sits to 13.8 or so is this normal? or anything to worry bout? also my oil pressure gauge hops around too 40 psi on start up the 6o when warm but when i stop fast it drops too then goes back up oil level good. fuel gauge does it too but thats normal on gm's. and on my after market pyro gauge since i put in my manual waste gate the highest temp i see is 650f to 700f degrees probe is in turbo
