Sunshine
Northern Lights
I've damaged the rubber boot on the front CV axle shaft nearest the wheel.
Looks like I've pinched it as the grease is oozing out with the top of the beaker bar when i was removing the hub assy.
Is it worth trying to repair it if so what would be the best way,I was thinking from the inside cone shaped peace of rubber..? what sort of grease is in there as this is light green in colour, could you use any other type of grease.
Thanx..:thumbsup:
Thanx..:thumbsup:
