HMF
Here are some pictures from upgrading my alternator:
I got the CS-144 alternator off of an Express van with a 5.0 gas engine. The rear bracket fit perfect on the 6.5TD. I also got the connector for the regulator with the alternator so I could make a pigtail, see pictures below.
The original 100A CS-130D:
Comparison of CS-130D and CS-144:
CS-144 rear bracket on left, CS-130D rear bracket on right (I meant to have the CS-144 on the right but messed up the picture): I got the CS-144 rear bracket from the junkyard along with the alternator.
CS-144 temporarily installed on engine mounting bracket:
Note difference in connectors:
CS-130D connector:
CS-144 connector:
I made an adapter pigtail to go in place of the factory CS-130D adapter pigtail. The factory CS-130D pigtail is on the left, the one I made for the CS-144 is on the right. I got the plug for the alternator along with the alternator when I got it from the junkyard.
The CS-144 installed on the engine. It fits like it was factory installed. That makes sense, since they were an option.
CS-130D connector:
CS-144 connector:
