Confirmation needed: 1998 7.4L Vortec to replace 1990 TBI
GM Guy
Manual Trans. 2WD Enthusiast
NW Kansas and SC Idaho
I posted this on another site, and i need confirmation.
Dad got a 1990 C3500 2wd C&C SM465 manual truck w/ a knocking 454 TBI.
He also bought a 1998 p-chassis w/ a 454 Vortec that runs great.
He wants to put the vortec into the truck, and run it on the factory TBI setup for simplicity. (not looking for alot of power)
I have been told one just transfers the stuff off the TBI onto the Vortec, even the intake manifold. i was told the only thing i would have to get is a timing chain cover, since the Vortec no longer needs a CPS. Is this talk about the TBI intake bolting on w/ no running issues true?
the reason i wondered about the manifold is that the SBC apparently needs a conversion manifold, but i was told the ports are the same between TBI and Vortec BBC. is this right?
the center 2 bolts on each side is normally the hang up but they can be shaved a bit to work perfectly for the 350 carb to 350 TBI to 350 Vortech. . .
Now the 454 i do believe is just a direct swap out tho i would keep the 454 TBI heads handy just in case. . .
BTW that 454 will run them 6.5's in to the ground all day any day. :thumbsup:
I'll take you knocking 454 to replace my 6.5-T boat anchor. :D
Mikey
That is what i thought. we will be hopefully doing this swap soon! also, the 90's flywheel should bolt on no problem, right? the p-chassis was auto.
if u don't like your 95, list some specs, and we'll see if i can can take it off your hands!
