Yachtcare
Recruit
- Messages
- 173
- Reaction score
- 2
The new pump arrived this afternoon. Already got the injector lines installed. Gonna try to get it on the engine today.
The tag on the pump reads......DB2829-4267 serial xxxxxxxx "Moose Junior"
The number corresponds to an '84-'85 military pump.
So it is clearly not a .31 plunger pump.
The documentation sent with the pump states that a "pyrometer is NOT an option with these pumps" and EGT's must be monitored. "Probes must be within 3" of the exhaust manifold. NO POST TURBO PYRO'S."
So, guess I will have to review the location of my probe in the downpipe.
Also states that "this pump has the potential to melt a piston in your engine, if you floor it and hold it there. The maximum HP this pump is capable of producing can only be achieved if your turbo is intercooled, and your turbo can supply whatever boost is required. That is not to say you will have problems with this pump on a stock turbo IDI. What it means is, that you will and must drive by the pyro, ALWAYS."
So it has clearly had the fuel delivery tweaked.
I figured on adding an ATT later this year.
