DieselSlug
Well this is the first snow that hit the ground and stayed for at least part of the day. These first pictures were taken in Fabius NY on Route 91 11/03/2012.
Looks cold! No thanks. Real pretty though. Im in shorts today
does yours leave chatter marks when you plow?
where your blade bounces up and down and leaves marks rather than plow smoothly
mine does it no matter what the surface. if I'm pushing a good size pile it's fine but when I try to clean up it's terrible. I've tried a couple of diff positions on the blade angle but doesn't seem to make any diff. from some of the reading I've done sounds like it is a more common occurence when you add a cutting edge, which I did.
Take the plow back off Mike or it'll NEVER snow there...
Not to get off subject but how did your mpg jump so much?
Not saying you cant get 21MPG highway but your fillups dont show it and I'm confused.
EDIT: NVM, I figured it out. Your partial fill up must be throwing it off until you finish the tank.
