So, tonight was the bi-annual trip to the local inspection lane. Had to sit in line for between 30-40 minutes. It's 86°F while in line. About 15 minutes after being in line, I noticed the coolant temperature gauge rising. Hmm, okay... rev it up a bit for more GPM in the coolant system, and more CFM through the radiator. Well, rev yes, coolant temp didn't drop, it went up. It maxed out at 215°F. Took off driving afterward, and within less than a 1/4 mile, was back down to 185°F.
Sounds like an air flow problem like the clutch is not engaging... but at what temp does the 5.7L/350 usually kick in the fan on an '01? 215°F seems a bit high. Is this a fan clutch condemnable offense? or am I expecting too much to keep it to 200-205 at idle with the AC on?
