RD400HP
I finally got my 95 started so I can put in the garage to pull the intake & change the fuel lines. While it was running I checked the voltage on pin F on the DLC it read about 14 volts shut truck off and you can hear the LP running.
Now when I put 12 volts to pin F with the key in the run position I cannot make the LP run am I doing something wrong here?
Mark
Mark
