BudTX
Edjumacated Redneck
Last winter when it got cold my truck would sometimes not move. The shifter worked fine, and would initally go into R, but then the shift indicator would blink (and sometimes disappear), the truck would act like it was in neutral and the RANGE SHIFT INHIBITED message would show up on the DIC.
No codes, and no CEL.
I called the 'way out-of-town tranny builder, who would not return my call. His phone answering toady was no help. :nonod:
I decided to replace the NSBU switch (purchased at a bus repair garage that services Allisons), and the problem seemed to go away.
Fast forward to this year, again, only when the temperatures are under 25 degrees F or so.
Same problem, and same message, but sometimes there is no DIC message and the CEL comes on. The code is 0841, indicating a valve issue in the tranny.
I can clear the code and coax the truck to finally go into gear. Once the tranny warms up it runs like a champ.
I can't figure out why this is only happening in the cold. There is no ice or moisture on the NSBU switch, and the truck is garaged when not driven.
Batteries are new, grounds are clean, tranny fluid level is in the middle of the crosshatch when hot, spin-on is new.
Any ideas - ?
Any ideas - ?
