Hi, i have to chanfe my crankshaft position sensor, however whe trying to take it out it hits on the power steering pump, is there any easy way to loosen the pump just to jiggle it a bit? If only it would be about 2 millimeters shorter it would slide right out. If not there is a way to loosen it i assume its just a lot of removing different components to get to the sensor?
