saratoga
Unpaid Help
Will someone do me a favor... pull the turbo intake off your truck while it's cold and check to see if there is any side-side movement when you grab the compressor shaft and try to move it?
I was doing some cleaning last weekend, decided for whatever reason to do this and was kind of startled when I was able to move the shaft. It didn't move easily, or much for that matter but I was able to move it.
There's no weird noises and it makes plenty of boost, doesn't use any oil, etc. Maybe I'm still paranoid from when I drove it across the state with the bad vane pos sensor and it did make funky noises when accelerating.
