DennisG01
In anticipation of possibly needing a new IP, I spoke with Pensacola Diesel. They mentioned they build IP's to the Stanadyne spec of 24-26cc's, usually towards the lower end of the spectrum. However, they could build it higher than that. What are your thoughts about having that done?
Also, is this the "Optic Bump" thing, or is that a separate mod? I'm searching, researching and learning, but still a little confused on how this stuff all relates to each other. Am I correct in assuming that this "24-26cc's" is the maximum amount of fuel that the IP can output?
