buddy
Active Member
The larger the housings and larger wheels it will make spooling more difficult, meaning not just lag, but also peak pressure, because larger turbos with great efficiency create less backpressure but get closer to creating as much boost pressure on the intake side and backpressure on the exhaust side. I believe the schoolcraft turbo is wastegated, so that just says the wheels themselves are smaller, less efficient ones but uses the wastegate to bypass the turbine to prevent too much backpressure and boost. I have seen versions of Kennedy programming, recent and dated, and neither would support enough fueling to hit even 20psi on the ATT. I run 20+ psi on the ATT with the fueling I program, but on a smaller turbo I could easily push 30+ psi, have done that with the GM4. If they can wasteage at 25psi that means the housings are a little smaller than ATT and the compressor wheel.
I just know I would never pay $1700 for a turbocharger. That is subjective, not objective. Im not even sure what you get for that $1700 since it says turbo assembly only.
Compressor maps and dyno numbers aren't the final word on what works well. I gladly accept all the objective, quantitative data of the ATT vs GMx on IAT, EGT, ECT, MPG, MPH, PSI, ect....that gives us qualitative information as well. The ATT kit is a good value. The schoolcraft may work as well, but is that as good of value, when I imagine you could get a knockoff similar to it for $320 on ebay.
The schoolcraft turbo probably maintains the off the line spooling performance better than the ATT, but I would find it hard to outperform the ATT when hauling heavy loads.
