robzombie4551
robzombie4551
I put a new remy alt. from A/A on 2 weeks ago along with new belt,and new W/P.from R/A.
Well less than 2000 miles later the rear bearing is shot and it stopped charging.
The tensioner seems fine, no binding/dirt or rust and has a pulley I bought 8 months ago on it.
It goes through the full range with a ton of resistance/ is this normal for this tensioner?
Bad alt.?or maybe time to change the tensioner? It is the original.
How do I know if it is bad. Usually they bind or break the spring, or they get wobbly. This one has none of that.Can I check it with a torque wrench and see if it has to much tension, and taking out the bearings. I know if it happens again in the next few weeks A/A will not honor the lifetime warranty,as it is limited, IE to what they feel is in their best interest not mine. BTW the old alt. was changed due to the diodes not the bearings and it was on there for atleast three years.
TIA.:mad2::mad2:
TIA.:mad2::mad2:
