colbythekid
I am in the market for new batteries and positive and negative cables for both sides. I was wondering if anyone had any input on what type of battery connection was better the GM side post or the top mount that every other car manufactures seems to use. I prefer the top mount ones when it comes to jump starting another car because it seems to provide better contact for the jumper cables.
Based on this principal I would assume that the top posts also provide more surface area for positive and ground connections. I figured that since I need to replace both the batteries and the cables at the same time if the top mounts are better I would pick up some batteries with the top mount and cables that are also top mount.
Thoughts?
Thank you
Colby
Thoughts?
Thank you
Colby
