B&M Shift Enhancer
I had one in my first 6.5. I bought the truck with a failing transmission. I put the B&M on it and it stopped slipping between gears and lasted for about another year before if finally gave up. It just increases line pressure electronically. Basically the same as part of what most shift kits do. It's a cheap, easy and quick way to get a little firmer shifts out of the truck.
Level 1 works fine but 2 is too much line pressure for longevity of the trans. Best to do the tweaks in the tune instead of with the B&M because you aren't just jacking uo the pressure "all the time"
