beerwolf
I have read and reread the posts on this and still cant seem to get it going.
- Year: 1995______
- Truck model and class (ie: c2500) C/K1500 4x4 Z71_________
- Automatic or Standard auto__________
- Mileage: (indicate miles or km) 425,000 km_________
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) IP,PMD,LP,OPS___________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? S –egr turbo______________
- Ambient outside temp: (indicate *C or *F) -2c__________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) truck stop pump_________
- What fuel additives are you using? Kleen flow___________
- Where are you located? South ontario_____________
- Air filter cleaned K&N_________
- Fuel filter 8000km_________
- CDR Valve? 25,000km________
- Coolant – last flushed/replaced at today_____________
- Oil – synthetic/regular, changed at today_regular_________
- Batteries – state of charge, (matched set) replaced at matched age?_____________
- Battery cables and grounds (removed, cleaned and tightened): _cleaned_____________
- Glow Plugs - how many miles on them? __?_______ What type? __?___________
- Injectors - last changed at _?_____________
- What were you doing when it happened? Driving down the street______________
- How was the truck running fine before this problem appeared? good_____________
- Has this problem ever happened before? no_______________________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) _Y___ And? none________
Diagnostics:
1] Starting:
1a] Does the engine start? _no________
1b] Does the engine crank over? _yes_______
1c] Are your batteries fully charged? _yes________
1d] Have you removed, cleaned, and tightened all battery connections? _yes______
1e] Does your Wait to Start light come on for a time? How long? _N/A
1f] Does your glow plug light come on? _yes ________ For how long? 10 sec________
1g] Do you see smoke from the exhaust while cranking? What color? none________
2a] Can you hear your lift pump working? _yes___________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _yes________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? _yes__________
2d] Loosen an injector line and crank the engine - does fuel come out?no _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? _yes__________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) _now remote(bumper)__________
3b] Condition of Extension harness (if used) Vendor or Homemade? _vendor________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. OK_________
3d] PMD Make:Stanadyne ___________
3e] PMD Age: used X3_____________
4] Stalling Issues
4a] Do you experience stalling only when hot? no____________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) _no_____
4c] Does pouring cool water over the IP seem to help with restarting? n/A_________
4d] Is stalling momentary (engine recovers)? N/A_________
4e] Does SES light come on when engine hiccups? __N/A_______
4f] Does cruise control quit working when engine hiccups? _N/A__________
4g] Does re-starting seem to reset engine, restoring cruise and power? _N/A________
4h] Changes to dash lights or instruments during stalling events? N/A___________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _no______
5b] Any bubbles or oil film in coolant overflow tank? no_______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _no_________
5d] Excessive white smoke from exhaust on cold start? At times_________
5e] Excessive black smoke from exhaust under hard acceleration? _yes_________
6] Performance Issues
6a] Do you have gauges? _no__________
6b] Maximum boost under load? ____________
6c] Have you added a performance PCM (reflash) or Chip? _no_____________
6d] Have you changed exhaust / downpipe / crossover? _yes__3”-4” no cat_____________
6e] Wastegate – mechanical or vacuum? _vaccuum_____________
7a] Single or dual thermostats? __single__________
7b] Have you replaced them lately? Manufacturer of replacements? _________
7c] Have you pulled and cleaned Radiator and coolers lately? Yes when I replaced engine 25,000KM ago____________
7d] Have you replaced the fan clutch? Manufacturer of replacement? no________
7e] (winter) Have you tested your antifreeze? Good to what temp? _-40_________
7f] (winter) Are you using a winter grille cover? no___________
List and describe any other factors which are not addressed in this checklist.
We can’t see, hear, smell, or touch your truck, so the more descriptive information you can give, the more likely it is that somebody can assist you
The day it quit in the morning -22, it was plugged in. Started very easy,went to work. After work (8.5 hrs) truck was hard to start. Had to fire it up 3x. Lots of black smoke and some white. Started out ran fine for 15 min then just died, almost like you turned off the key. Would not restart.
Towed home. 3 weeks ago, been in my garage since.
Fuel at filter, T vavle, top of IP
Since then I have replaced, PMD with remote harness on bumper, LP, OPS, IP(used but tesed in reputable diesel shop ) Everything I have changed so far has not made a difference. Still no fuel at injectors which was where I started
- Year: 1995______
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
