You MUST disable the glow plugs if you're going to try using starting fluid. Starting fluid doesn't directly damage glow plugs, but if the plugs are hot when the starting fluid hits them, the starting fluid will instantly explode, and if this happens with an intake valve open(which it normally does), you get a NASTY explosion out the intake which can blow intakes apart, take out turbos, turbo lines air boxes, or anything else i nthe intake tract. And the explosion from it can blow the glow plug tip off, and send that nice piece of glow plug tip down into the cylinder going through a piston or get lodged on top of a valve causing a valve to smack a piston top. Yes, using starting fluid with glow plugs IS this dangerous. MANY an engine has been lost to it. Engines with intake grid heaters like CUMMINS(and most late model diesels that use both) are even worse. Since the heat source is in the intake, as soon as you spray it in the explosion takes place blowing everything apart. it tends to not do the internal engine damage since the heat source is external to the engine, but the damage it does externally is almost always worse.
