dusty
hey i have a 2003 6.6 durmax will it hurt anything if i change the anti freeze to the old green stuff thanks in advance
The biggest problem with Dexcool is that it didnt last as long as GM hyped it for. Its part of the ongoing process of GM creating a revenue stream for things they can license, like the new Dexos approved oils.
If you want a "Forever" coolant go with Evans NPG+, it's a little more than antifreeze but never goes bad and won't kill animals.....
What about the dmax head gaskets failing?
The plastic intake manifold gaskets on the 3400 and other gassers.. Bad gaskets?
What's the verdict on these?
Coolant doesn't go bad, it is the additives and saturation of cantaminets that makes it go bad. You can filter and put an additive package back in it and run it another 5 years and just keep doing that so long as the levels in it stay proper.
