About 1 month shy of a year since 6.5L did this. Been kicking it around since and finally couldn't resist anymore with the 10% off sale at XDP.
We will see if dad notices that the ATT turbo is secretly replaced with a BD Quick Spool Valve enhanced ATT turbo. :hihi:
This will be on the 6.2 diesel in the 1995 suburban.
First off the BD Quick Spool Valve is huge! It is also, and there is simply no other way to say this, built like a brick s#ithouse! So I don't feel so bad about dropping $600.00 on it because it appears to be a overkill quality heavy duty part. I put a can of WD-40 in the picture to give everyone a sense of scale. Also having the massive turbo out of the picture helps. Going to be a bit of a project to get it shoehorned in.
The AC can stay, but you need to rotate the accumulator line to the compressor. So the AC needs to be pulled down. This is going to cause a clearance mess with the K47 and flat panel air cleaner housings. The 1995 has a pressurized surge tank that has to move. Stay tuned for the solution to the issues.
