hereismylife
formerly j k auto
I went back to 1st post, I know you probably gonna hate to hear this, but clean gnds also imperative for proper charging and maintaining tron flow to batts, and since you have 2 batts the cross tie hot lead to the other batt needs to be spiffy, the 1 wire as supplied by GM on mine and most other is up to task if you are having charging issues, need to find out why, is charge wire corroded under the insulation, I've seen that diminish alt charging output before.
Do you have a load cell, 1 dead cell in a pair of batts will diminish entire charging/electrical system capabilities?
I replaced all my wires last yr and have 2 new optima batts. The problem I am having is when my front & rear blower with the lights on my voltage is to low for me. With all that on it seems like the alt juice is not getting to the batts fast enough. After a long drive till you park it for the night. The next morning it just takes to long to charge it back up to 14v. It did this since day one when I bought the truck. Maybe I can get a video of what I am saying.
Maybe my alt is low or going out.....
The only other thing that comes to mine is some days the gauge will show low after cycling the glow plugs. Sometimes it takes to the next start up to get it to 14v and sometimes up to 2 days. I never did figure this out.:mad2:
This is why I wanted to change my alt wire
1. It is the oldest wire on the system ( 14 yrs old)
2. It looks like it could be replaced
3. maybe it is my problem ( trial n error )
