dmaxfireman
'Can Do' kindof Guy
just brought this ol girl home the other night... have not run the serial # yet but guy told me it was a 39. if it is somebody added foot brakes and head lights to it. also has factory hydraulics on the pto. so far, needs new 6v battery, i rebuilt the starter, had gear lube in trans instead of the sae 20w that its supposed to have with the hydaulics option. now the bad news..... quite a bit of coolant in the oil. 4 options from bad to worse; freeze plugs in head, head gasket, cyl sleeve orings, cracked block...... so far negative on the freeze plugs and the cyl sleeves from what i can tell. so head gaskets or cracked block. i'm really hoping that its a head gasket. got the pressure tester on and going to leave it over night to look for seepage.
got it for snow plowing the driveway so worst case i will bars leak it for the winter and rebuild in the summer, or maybe i will try to get a head gasket in the next couple days, looks VERY easy under there in terms of swapping.
heres a couple videos of the wife driving it around the yard before i tore it down
[video=youtube_share;YMiTUZJgL0E]http://youtu.be/YMiTUZJgL0E[/video]
[video=youtube_share;4M9cA6JqweQ]http://youtu.be/4M9cA6JqweQ[/video]
