Okay guys hopefully one of y'all are online.. before I start I will point out.. I have my ABS fuse out from under the hood as well as the brake fuse out that's in the side of the dash, they are out because the wheel sensors are screwing with the transmission somehow haven't figured that out..
So here's what's happening ,. Keep in mind I am a very long way from home. I went to get on the interstate, truck has been running fine today, I hit approximately 65 miles an hour and it's like the accelerator dies.. the truck does not shut off, but it's like you took your foot off the accelerator ,even if you push it to the floor. If you take your foot off the accelerator let the truck slowed down a little then start pushing it again all is good.. get her back up to about 65 or so and she does it again.. I have multiple spare pmd's on board.. but does anybody have any input or could this possibly be the accelerator sensor going bad.. or could having those fuses out be causing it... I'm leery of getting back on the interstate right now to test out putting the fuses in or a new PMD so I'll sit here for a while and see if anybody responds..
