- Staff
- #41
I know you've said before that two of you are posting under one name, but that "we" thing is freaking me out man!
Myself, I've been trying to find a way to use the PWM signal from the 6.5 PCM to run a PWM driven VVT turbo control, but it is proving to be difficult to fabricate on a part time basis. My work is eating up a lot of time. I have to conduct SAR OPS on a 24 hr basis, run my section of 8 Engineers and oversee an Entire Squadron (100+ trouble makers!) as the Squadron Warrant Officer. Not much time left for cocky to play in the garage! 8 more years to retirement, lots of time to play then.....
But, the idea is something like a HE351VE run off the stock 6.5 PCM.
Neat, clean and fully integrated and controlled by the .cal files in the PCM....
Have you considered teh KISS method to control it? I know they used to ahve VVT turbos that had an external wastegate arm that controlled the vanes. On a set-up like this you could use the stock vacuum canister to control it and hook a spring to it to hold the turbo open. As it applied vacuum it would pull it to the closed vane position which would cause boost to rise, and as it releases vacuum the return spring would pull them to the open position and lower boost. It seems like a simple enough way to control the VVT mechanism via a stock 6.5 PCM.
