countryboy69
Ok this is a new trick that years of 6.x trucks hasnt done to me.
Friday I drove up north in my 01 6.5 db2 truck. 2.5 hour drive one way. run like a top all the way to Indy. Was in the trade show for about 8 hours and it was a little hard to start. Chocked it up to being cold and run hard coming up. Ran fine coming back south. Stopped at an old friends before going home. Went to leave and it wouldn't start. Lost prime is how its acting. Kept bleeding the filter and cranking it until she finally fired. Ran fine coming home.
Next morning took a little extra time to get it started. Still runs fine but if you let off throttle too quick it will die. Fires right back up.
Went home and changed filter, checked glow plugs, hunted for leaks in the fuel lines that might let air in. Nothing!
It started sunday with a little bit of work. That evening it wouldn't even start. Gave up. Jumped it and got it running this morning.
Longer it sets the harder it is to start. Have to prime system every time. Electric pump is working and has decent flow but I dont know actual pressure. Fuel filter gets air in it. Bleeder on the crossover has air too for a few seconds. Lines are all fairly new and DB2 pump has about 2000 miles since brand new from Stanadyne. Not a reman it is brand new. It also started having a fuel knock occasionally. I have checked all the obvious but experience has me thinking injector. But it runs perfect when its running. Any suggestions?
