My Suburban is running very well, no engine issues at all, so I'll just say that up front, nothing urgent about these problems.
My cruise control stopped working a few days ago. Last time this happened I had a bad battery and voltage was low, once I installed new batteries the cruise operated fine. I use it all the time. It won't engage at all.
Also, my high idle switches stopped working, probably related.
What would cause these 2 items to not work, but everything else to run perfectly? I'm thinking I need to pull the PCM and check connectors there, what else should I look at?
Thanks, David
Thanks, David
