drshock
I had an issue with the original nylon rear heater hose tee cracked and leaking on my 1999 Chevrolet Suburban diesel. I found a related thread in the forum about this here - http://www.thetruckstop.us/forum/showthread.php?26743-1999-Sub-rear-heat-tees-part-number-anyone
But the GM hose/tee assembly mentioned there, 15979269, has now been discontinued.
The tee is a proprietary design, 3/4 x 3/4 x 5/8. Not something you can pick up over the counter anywhere and I really don't like making modifications from the factory design. So I wanted to share here that fortunately I recognized this EXACT same hose tee is used on the 1992-1996 Chevrolet Impala!
It is 100% identical with the same casting marks and design as original (I am the original owner of this Suburban). Contrary to some Google hits out there, no flow restrictor is used in the tee for the 1996-1999 design. So you just need the tee.
GM part 12522867 is what you need. I don't understand why GM missed this and did not list this tee number as still available under the Suburbarn parts list but here it is - http://www.rmsautoparts.com/proddetail.php?prod=12522867
Hope this helps someone else.
