D2 Cat
I just acquired this truck with 226,000 miles on the clock, 1/2 T, Z-71, 4x4. It has not ran in at least two months.
PO said the engine was replaced 40,000 ago, replaced PMD recently, changed fuel filter and lift pump last fall. They said it ran fine until the weather started getting colder (in Nov) then it seemed to b losing power, and then stall. They thought it was a fuel delivery problem, because it was running perfectly until the moment it cut out. That's when they replaced the LP and fuel filter. It would then start up, it warmed up for about 15 minutes, then about 5 minutes into the drive it stalled and cut out again. It would turn over and start and not stay running long enough to drive. They gave up. They want a gas truck!!! I have to assume all the claims of a different engine are just that, I have no receipts.
It turns over good, just won't fire. I checked the LP and no power there. I jumped a battery to the LP and it pumps fuel. The fuel tank was empty when I tried the LP, so I added 5 gals. When it pumped there was a lot of air, but I expected that. I tried to bleed it, but never succeeded. Later that day I could smell diesel and see in the moisture in the driveway there was some diesel running off.
I removed the fuel monitor and cleaned it. It was filthy. It had a new filter in it (by PO) and I think the screw on cap was not tight. It was also leaking at the WIF sensor. I replaced that O-ring. I removed the fuel heater. That gasket seemed OK, but I did add a touch of permatex #2 on both sides for good measure. I will replace the hoses coming out of it when I install it.
I replaced the OPS and the fuel relay. I ran 12 Volts from battery to "G" connection on OBD terminal and still had no power to LP.
What do I need to do to check power to the LP? Is new OPS not functioning properly? Wire at OPS connector not working? Can I jump past the OPS to get fuel to see if this thing will come to life?
All these things I have done are things I learned snooping here are critical points on these trucks. I am not a mechanic, just an eternal optimist!
