New injs and glow plugs seems to have been able to fix the cold start problem.but still have lots of smoke.going to do the air test .and install knew lift pump would air or low fuel pressure make it smoke? Also it runs good under load but just to review it up to 2000rpm it starts to cut out and smoke
. . . The coolant is always good.Right up to level .it smells like fuel not coolant.
It seems you have a few of these 6.5's - but the mechanical DB2 will "try" to suck fuel if the lift pump is not doing its job while a DS4 based vehicle will usually just cut off at coast or returning to idle. The DB2 will start and do what you are describing at higher a rpm if it cannot suck enough fuel. Low fuel pressure is taking life out of the IP because there is no fuel for lubrication of the IP. You do not say if the 2000 rpm cut out and smoke is cold or warm.
If the coolant smells like fuel - you may have a head gasket leak - which is popular at the rear cylinders which tend to run hot. A cheap and ugly fix is sodium silicate head gasket seal. But usually most often a head gasket leak means the coolant level will drop over time. You have to check the coolant system pressure to get a better idea when warm.
You say that new injectors and glow plugs fixed the cold start problem, however the first thing to do is get a REAL dependable lift pump on the vehicle.
For instance the AIRTEX E3158 has a spec of 14 psi and that is that is one of the pumps for that vehicle - but I can tell you I have seen four of those pumps in a row loose pumping pressure in 1 week.
Put on a rotary type immersion pump rated at that with a back flow valve - it will work and you can hear it running and know it is pumping because that is a MOTOR pumping through a rotary vane impeller - NOT a solenoid buzzing back and forth using a spring to push fuel.
I hate to rag on this - but the new OEM style lift pumps being produced today do not work and not for long. I have seen them stop pumping pressure in one day.
Otherwise I am with GM Guy from
https://www.thetruckstop.us/forum/threads/93-td-hard-cold-start-with-lots-of-smoke.47715/post-564224 that it is the cold start system.
I am also with Husker6.5 at
https://www.thetruckstop.us/forum/threads/93-td-hard-cold-start-with-lots-of-smoke.47715/post-563761 that the DB2 should always be run with an additive to add extra lubrication to the fuel because today's ULSD - which is all you can get - is a bit too "dry" to lubricate properly a DB2 for long life.
There are a lot of people who refuse to believe ULSD will harm the older injection pumps - but I have seen the truth - there was a Brand new - not rebuilt - DS4 that seized not even one week into operation and DB2's come in for rebuild with scarred plungers . . .
My two cents
