will do, thanks, went through the grounds, what general area would the fusible link be in if thats the problemStart at battery connections. Load test batteries. If you haven’t replaced the crappy side mount cables for top mount yet, check the little puck that connects battery cables to each other. Check connections at starter and ground cable.
