Clark20ry
Agent #58 OB-DII A(ALCU)
Alright I am at my wits end. I have an 89 GMC Suburban 5.7 K motor with the TBI. Simple truck with a pain in the butt issue. The motor is about a year old and was running ok for a about a year. We started having a sputtering issue. I did a little research and a common issue with this motor is P/U coil in the distributor. I changed that out and seemed to make the truck run better. Here is the problem, these motors have an electronic spark control not vacuum advance. So to time the motor you unplug the Timing Control Wire set the timing and then re-connect the timing control wire. The truck runs great with the wire disconnected almost to good except the timing is all the way advanced so I get a real bad ping/knock under load. If I plug the wire back in the truck runs rough barely idles and dies when you put it in gear. It will stay running with some convincing, but still knocks/pings under load. I don't have any codes. I will put a list of what has been replaced. I am about ready to set it on fire... I love this truck yes its a gasser but its a great Suburban.
New Pick up coil
New Distributor w/module
New coil
New Spark control module
I have checked the fuel pressure and its good. Its timed correctly. I am just not sure and I have had it a garage for week and it stumped the mechanics there.
Any help would be appreciated.
New Pick up coil
New coil
