Hi: Im new to diesels, i came across a 2000 gmc 3500 with a 6.5l diesel engine, I picked it up cheap with a plow. The only thing I had to do was put 1 lifter in it, and put it back together, the lifter had went bad at 61k miles, I did not here it run befor buying it, it was apart.It starts right up and sounds ok but seems to smoke like its getting too much fuel. I haven't drove it yet, don't want to mess it up if too much fuel. Could it be a bad injector or something to do with the valve train everyhing looked ok on the rocker arms. If one or more of the injectors is leaking by, would I be able to tell by cracking the fuel line and see the smoke stop? I know the engine should stumble. Any Ideas? Thanks. Mike
