great white
Hi all.
We bought a 2011 30 footer (travel trailer) this year. Dry weight 5,228 and GVWR 6629 lbs.
I've got a 98 6.5 "F" 4l80e 4x4 with 4:10 gearing. You can see more in my sig line. Really, the truck is pretty much stock right now.
The dealer just got in a "classic" model which is a 35 footer, dry weight 6389 and gvwr 8597lbs.
My current trailer is unused, since it was bought end of season and we intended to use it first thing in the spring. It still has the wrap on the mattress and the cover on the toilet.
IOW, all I've done is tow it home so I'm not even sure yet how my truck will deal with towing it. I do know that towing it home, my ol' truck didn't hardly even know it was back there. But that was no faster than 60kph (through town) and mostly flat. The few small hills we went over didn't seem to effect anything.
I've towed before, but not with this truck and not with this weight.
We were in to the dealer the other day buying some small bits and saw the bigger model. More storage, atrium windows, bigger floor plan, etc. They offered us a trade in deal (out of our current trailer clean) and a good price on upgrading to the larger model. Basically, just the price difference between the two models.
This is really appealing to us as we really prefer the larger model and probably would have bought it if it had been on the lot when we bought the current 30 footer.
My equalizer hitch is rated well above the weight with the bars installed and the truck is rated in the owners manual for 10,000 lbs with an equalizer hitch. My controller is a Tekonsha P3, which is pretty much their top of the line one. At least it is for Tekonsha....
Neither trailer is a fifth wheel and we don't want to go that way anyways.
I've done the usual clean the rad, it's already got the 9 bladed steel fan and high flow pump form the factory. I'm also a "tuner" and have the proper software for OBDII (tunercat II and my truck's VDF) so I'll be tweaking the program for towing.
My question is should there be much difference between towing either trailer? Will my 98 even care about another 1500-2000 lbs in loaded trailer weight?
We really want to take the deal, I'm just unsure of adding any more load to my 98....
