OK my 6.5 has a new Injection pump (about 2 years old), New tank sock (about 2 years old), New PMD (a few days old Heath & new backup with same results), Fuel filter (about a month old looks new). New PCM about 2.5 years ago. New air filter (about a month ago) Was doing well for months, started the "bite the shark", so contacted Heath (pmd was about 2 years old at that point). Put backup on (a cheap Dorman but works fine) It solved that problem, got replacement Heath and all was well for a couple of weeks. Then it started sputtering when coming from a stop or low rpm. It seemed to do fine once you got through it until I stop or slow down again. Changing to the backup PMD had the same results. No codes. I always use Diesel Kleen when filling up.
Fuel pressure from the filter 4psi when running, almost 6psi with just Key on (its a 2000 k3500 diesel). 4.5psi from T valve when running idling. Got 4 to 5 when revving the engine. Ironically I could not make it sputter while I had the gauge on it. The LP is loud and working. All the fuel lines appear in good condition. The ones behind the FFM looks fairly new and in good shape. Did not see any air bubbles when checking with clear tubing (I have clear tubing for my gauge)
Just for the record I'm not a mechanic (I'm a You Tube mechanic lol). But in the past the great minds of this site have helped me to fix things.
Another thing, it seems to be worse if the AC is on. I appreciate any help you can give me. I only have 180,000 miles on it and hope to get 300,000 before retiring it!.
