FordGuy100
Hello all,
I found this site by searching for DS4 pump info. Obviously I'm a Ford guy so I feel a little "dirty" being over here
I come to seek info on mods you guys do to your 6.5's. I've read of some pump tricks that were a little over my head (obviously I'm a Ford guy...what isnt over my head
). I want to know what kind of pump tricks you guys have up your sleeve for the DB2, DB4, or DS4. We Ford IDI owners are lagging behind for sure on this.
I own a 1985 Ford F250 4x4 (Dana 44HD TTB...yikes almost as bad as that truck brand with IFS
) 6.9/T19 (gotta love a non overdrive tranny... still gets 17mpg at 65mph/2300rpms). Grandfather bought it new. Passed it down to me with 113K miles on it 3 years ago. I have since added a 093 ATS wastegated turbo (T3/T4 hybrid), ARP head studs, 4" exhaust, ISSPRO Tach, boost, pyro, oil and water temp gauges. Plus a full paint job and other stuff. You can search my vids on youtube, under the same user name.
Basically I have come to seek your wisdom...what do you guys do to get power out of your rigs? Easy things, hard things, I wanna hear them. Or point me to a thread...even though I drive a Ferd I can read ):h
6.9/7.3 mod support isnt high, be we have strong following. We do need to address some things. Turbo, pump, injectors, timing, compression ratio.
I do have a source for pumps. He calls them moose pumps...and they do work as advertise. The regular moose pump flows 90mm^3/1000 strokes, while the super moose pump flows 120mm^3. I have seen dyno sheets of moose injectors (emd'ed tips) and a regular moose pump...put down 205 hp and 460ft lbs of torque...all with a reeeeeeallly restrictive turbo. Those were the only mods. Heck I can see 15+psi of boost at 2400rpm's...but I cringe to think of the air inlet temperatures or how far out of its effeciency range it is.
My next motor I build will look like this. Bottom end balanced to 4000rpm's. .030 off the top of the pistons (only way we can lower compression without going custom). Moose injectors and super moose pump. Custom intake. ARP studs everywhere. Turbo gets tricky. Either a DT466 turbo, a SD 7.3 turbo (wastegated), or a ball bearing T3 with a T70 compressor on it. Or maybe something wacky like a 6.0 powerstroke turbo (nightmare with the VGT).
Fill me in Guys :thumbsup:
:iamwithstupid:
:iamwithstupid:
