Running 6V plugs off a 12V solenoid, found the problem
I would highly recommend a 12V Bosch Duraterm, or a recent model AC Delco 12V plug. AC Delcos used to swell too but recent models have corrected that.
My GM4 turbo is 17 years young and still going strong, occasioanlly putting out 20+ psi when I want to. Engine cant get enough air, it loves it. Of course would be better if it was cool air, and the ATT turbo I also have is better for that and more efficient in that range. ATT is non-wastegated, much larger turbine, needs a bit more RPM to get it spooling fast, but works real well.
Real familiar with the glow plugs and ohms. However, I wonder if your later glow plug controllers actually measure the ohms, or if they go off of battery voltage as our do. Because one that is high ohms wont draw current so wont draw down the battery so it wont glow as long because it thinks battery is still charged from being running or that the higher voltage would heat the plugs up faster or whatever GM was thinking with that programming. The lookup table for glow plug time looks for battery voltage and as battery voltage increases glow time decreases. and the other side of that lookup table is engine temperature (as engine temp increases glow time decreases). It is common to have a couple bad plugs in our trucks and glow time will just always be like 5 seconds whether its warm or cold out, and your battery will only draw down to like 12V, instead of 11 or 10.5V.
Do you have a schematic of the glow plug system or operational description of the system? I'm intrugued that the controller would work that way and would really like to see that. A regulated plug should go to a high resistance just like any other hot plug, however it will go higher once its hot to regulate it from overheating and if it starts to cool before the cycle is over resistance would go down to heat up again.
I have also been interested in how the mechanical guys time their IPs, so this is for 6.5 knowledge too that maybe I could find in the 6.2 section. I am intimately familair with timing the electronic stuff, but not the mechanical ones. Very interested in why you wouldnt be able to run 17-22* idle advance like GM did with the electronic pumps. Maybe just one more benefit of precision injection
You dont even have to put it to higher than 10* crank advance at idle, but with increased internal pressure it would go higher with higher fuel rates. thats how the fuel rate is controlled, by increasing pressure with RPM.
You can also try to port the precup mouths. there is a thread here about doing that. GM had like 5 different precup designs, but some people port it out a little larger that GM's largest option.
