6.5 custom chip tune.
marvgarr
Active Member
kingman az
Who does custom chip tuning I think the tuner I was going to use fell through. I need totally custom not the generic chips that are out there.
Some things I need custom.
The vss signal ppm needs to be changed.
The trans needs tuned out.
Custom fuel and timing mapping.
Over boost tuned out.
I probably missed a lot of things.
This is for my custom build.
THEFERMANATOR
FRANKENBURBAN
Staff member
Lead Moderator
ZEPHYRHILLS FL
I thought KOJO just did base tunes.
No, KOJO does it all. HEATH may be able to do it as well. I think KENNEDY uses WESTERS software, if so he's a no go for what you're after. Check with Leroy as I think he can get you KOJO, or go through Slim who works with KOJO.
