A way of oiling your turbo.
I thought the only difference in oil pans besides 1 or 2 piece seal was hummer or pick-up.
So no one makes a manifold that will work to turbo it? I have to swap heads? correct or incorrect?
i thought you did have to swap heads im getting confused now
1982 trucks with course thread heads are the only one that use different injectors. so if you get short body 6.5 injectors they will interchange with your 6.2 heads
