bison
Lets take it apart.
Pic 1) the gear reduction starter as we all know it.
P 2) One can clearly see the shiny narrow part between the mounting bolts where the starter contacts the block,no wonder that the little bracket on the rear of the starter is must to keep the starter steady to the block. Without it there is just to much force on the 2 bolts to keep them from fatiqueing and then breaking off.
P 3) Take out the 2 little screws( there's an 0 ring on them) holding the brush holder( inside) to the end cap.
P 4) unbolt the cable from the field housing to the solenoid(forgot pic) and take the 2 long trough bolts out .
I'm missing pictures,and they are not in order either.i don't know why?
Tap the end cap loose with the hammer,the brush holder will stay in place.
There is an 0 ring on the field housing as you can see in the bottom center right pic.
There are 4 brushes in all.2 of them are attached to the fields and have to be taken out of their spring loaded slots by prying the spring outwards with a suitable tool.A small screw driver like you see in the bottom pic works best.
The other 2 brushes can pulled out a bit and be wedged between the slot and the spring like in the bottom pic..
Now you can take the brusholder off the armature, and pull the armature straight up and out.
With a little tap to the side the Field housing can be removed as well.(there's a small dowel in between the intermidiate housing and the field housing,don't lose it.(it will show in the next couple pics)
Bottom pic)Take the 2 bolts out that hold the housing to the nose cone and pry the halves apart,Tapping on both sides to get some room for a screw driver to pry with.
More later
More later
