After my 1995 k2500 smashed up its ds4, I swapped in a db2 off the truck that donated my current engine. It ran fine for a few months, and suddenly developed a miss/rough idle. I put new injectors in it with no change. Found a fuel supply line leak and fixed it which makes it feel more rough and less misfire.
The weird stuff is that it rolls white smoke with anything less than full advance, which brings the smoke to a steady haze. There is also a weird whuffing sound from the right bank which might be an exhaust leak between the turbo and downpipe. Is there supposed to be some kind of gasket there?
Right now I'm thinking either the pump is dead or the timing chain stretched or jumped a tooth. Any thoughts?
