I read some of TDGs stuff, disagree with some of it, some shows potential, what I saw what he was doing mechanically with the 5068, I looked at with Diesel Pro at his shop one time when I visited there, is a band aid IMO with marginal potential.
What Bill & others are accomplishing with programming are about as good as it gets IMO.
Unless you put bigger plungers in the IP you can only deliver X volume, you can change the timing of the injection event with cam rings/ramping position with bumps and such, but driveability/mpg can, and often does suffer, far better from what I've seen is to do a quality reflash, and make sure the IP never suffers from low flow ie FTB/FRB-5
