Yachtcare
Recruit
- Messages
- 173
- Reaction score
- 2
Regarding truck in sig below.
Tranny running rather hot. 210-230*(sensor in test port on driver side) Coolers run thru rad first, then auxiliary on front of cooling stack, then thru a cooler mounted under the cab with a fan on it. Stock pan and fluid correct on stick.
In past couple of days it has been running at the hotter temps, around 190-195* before that(stat temp) unit has about 250K miles, AFAIK. Seems I've lost 3rd and OD. (Running about 3000 rpm at 45-50 mph, with 4.10 gears). No SES codes.
While I'd love to just replace with a fresh unit, $$ a bit tight now. Any ideas on trouble shooting would be appreciated. Need to get a few more months of life out of it.
