millsroger
OK-the issues first--Select first, you get first and second. Select second, you get first and second. Only thing that changes is the 1-2 shift point.
Not all of you may think of this as an issue but I do. I learned along time ago that starting on snow or ice is often better done in second gear due to the reduced torque. No such thing with this tranny. Also, off road if I want first gear I don't want it slamming into second.
One other issue is the TCC in normal drive. Some of the hills I need to pull loaded down with water tanks will not pull in fourth. Shifting to drive keeps it from trying, but, the TCC is still kicking in and out. This is heavy throttle and makes me worry about the TCC clutch.
Have read the posts on toggle switch overrides, and read up on various manual shift kits. None are a good solution and some confuse the ECM and throw error codes.
Well, I since I had been in conversation with SS re a chip any way, and the TCM and ECM use the same PROM, I inquired about changing the transmission table. Answer I got was "we can do that with no codes". Same price, just have to ask.
So, here is the way the tranny would work--first is only first, second is only second, Drive has no TCC, Overdrive is normal. They can also back down the part throttle shift points when in Low Range so it isn't as harsh.
The game plan is those changes to the TCM portion of the chip, ECM portion per their 'mild' upgrade and the small Transgo kit that has the pressure regulators but not the reprogramed shifts.
Any comments or observations are welcome and better now than later.
