4l80e rev and neutral safety
If you added it in, then you can eithet use a setup on the column like a 700r4 used, or if you have a 95+ trans with a nsbu on it, you can easily wire it in to work. Just need to figure out which is easiest for you to do with your setup.
If your 4l80e had a cable shifter stock, then it should have the bosses on the case for the nsbu to put it there, otherwise you will have to improvise as the stock setup worked via the column.
